Rotax 717 and 720 reliability
Jimwhall
Looking at a couple of 1999 Sea Doos. I'm just looking for a couple of years of fun with my older sons. I know these are old.
Sea test checks out. Hoses look good. Compression is good. Other than that, I've heard these gen Rotax engines have good reputations for reliability. Is this true? If I can get a couple summers out of them for the price I'd be okay.
Scott06
it does come down to how they were maintained, oil used and if they ran lean. If compression is still good that likely means it was reasonably cared for.
Not exactly the same engine but we just sold our 2004 GTI RFI LE (787 engine) with just shy of 300 hrs on it. We bought it with about 100 hrs 14 years ago, so fairly new. Always used the XPS synthetic oil, the chit is expensive ($60/gal) but we only used about 3 qts a year ...
I rebuilt the jet pump and wear ring twice. Had an issue with magneto and the exhaust manifold core plugs leaking , but basically was trouble free enough to keep that long. What finally tipped me over the edge was the crankshaft seals on the rotary intake valve started to leak oil into the crank case when not in use. Found this out the hard way when it was hydro locked this spring after sitting all winter( I had topped off the oil reservoir in fall). Engine still has about 145 psi compression , but to do the seals engine has to come out and take the crank out... so engine needs tore down.
I eeked through the season by clamping off the hose to the oil reservoir when not in use. Disclosed this when I sold it.
Bottom line if the ski has been reasonably cared for and doest look like a pile of chit for a small investment and some skinned knuckles you can get on the water.
Jimwhall
So I pulled the trigger on them. Took them out two days ago. Son and his buddy had a ball with them. Only downside is one is a bit boggy now and a bit slower than it was when I did the sea test, but he was still able to move around 40 and the hole shot was good. Will likely winterize them soon and then see about the slower ski more next spring.
