Hello. The deck on my 16ft tri-hull was saturated with rain water between the fiberglass deck and hull. I cut out a few 1 ft squares of the deck to let it dry since the spring and it's finally dry now. The plywood covering the foam is soft like cardboard, and the whole deck is separated from the plywood. I do not plan to replace the whole deck....only the places that I cut out.
What should I use to fill in low spots in the foam?
Should I just pour epoxy in and then place the squares back in and then glass the seams?
What do you guys recommend?
Your info is appreciated!!
