Lou C
- Joined
- Nov 10, 2002
- 14,063
Dennis @ Moore Performance referred me to GLM directly for warranty. I sent them some pics, and they are going to send me another manifold, and throw in the one rubber coupler (elbow to U-pipe) that I need also. I think it's about a $25 part. I guess that'll work. Just ready to get it done and out on the water again.
I found out something I didn't know about the V6 during this too - the exhaust ports aren't evenly spaced, but the manifold fits either side because the heads aren't mirror imaged. I thought they were left and right specific.
That is true the cyl heads are identical and so are the Volvo style exhaust manifolds. The manifolds have water ports on both ends to allow for that. What GM did when they created the V6 was remove one center cyl on each side from the 350 (5.7) V8. So the bore and stroke is identical to the 5.7 but obviously the crankshaft and cams are different. The later model 4.3s have a balance shaft to reduce vibrations caused by the 90* included angle of the cyls. A balanced V6 will have a 60* angle but doing it this way allowed them to use the same tooling used for the V8.
