So we picked up a 1990 Starcraft Heritage 1901 this August. It appeared to be in fantastic shape and treated us very well for the season. As I was pulling it out last week I found out there are a few soft spots in the floor towards the engine compartment. As I looked further, it appears that Starcraft drilled a few 1 inch holes for drainage through the stringers in the bilge area on the left and right. I felt one side and it was solid wood, he other, mush.
So, I know I have at least a partially rotten stringers and floor. I am assuming (hoping, praying) that the transom is solid. I do know that it appears that the transom could be removed without pulling the cap.
I am a little handy, but not sure I could pull off a full stringer and floor replacement alone. My major concern is dealing with pulling the engine and being a beginner with fiberglass. I also want to keep costs reasonable. I just read a post where Oops said a floor/stringer/transom is $5-7k. if that is the case then I am afraid to say I will need to get rid of it or come up with some way to reduce the costs. So I guess that is my question. How can I pull this off for under 4k? Can I do some of the demo and re-construction myself and let a shop do the stuff I cant? Is this feasible? Also, I am in Syracuse NY, so doing any work between Nov-Mar is pretty much out of the question unless I find a way to fit it in my garage.
Here are some boat specs. 19 ft Open bow, 3.0 Merc. Fiberglass ( One of the few Starcraft ones I am sure)
