rotten wire in outdrive
bigdan1
bought a 1985 doral 164 with a 140HP mercruiser 3.0L and outdrive ....
engine block is cracked from not being drained for winter ....
I already have the replacement engine on hand .....
when i pulled the engine out , i noticed that there is two double wires coming out of the outdrive .one goes to the trim pump (split in two )
the other one is totally rotten ......
are those wires exclusively for the trim pump ?
if so ,do I have to remove the whole outdrive to fix those ?
and then, where can I download my outdrive service manual ?
thanks a lot for your advices ...;-)
bigdan1
Re: rotten wire in outdrive
included is a pic of the wires the rotten one already cut but it wont weld at all ,too damaged .
<a href="http://s292.photobucket.com/albums/mm16/bigdan911/?action=view&current=P1160274.jpg" target="_blank"><img src="http://i292.photobucket.com/albums/mm16/bigdan911/P1160274.jpg" border="0" alt="fils outdrive">
paultjohnson
Most likely its for the trim limit switch The other one would be for the trim sending unit - to the dash gauge
paultjohnson
And yeah outdrive and bellhousing gotta come off At that point you should change ujoint and shift cable bellows, and water hose, check gimble bearing and u joints
Fishermark
Most people forget trying to replace the trim limit switch and the sender. A lot of work for very little gain.
Having said that, you do need to pull the outdrive if you haven't already to check the various parts as mentioned above. You will also need to check your engine alignment when you reinstall your new engine.
bigdan1
second attempt on pic
Fishermark
Here's the pic you tried to post. (If you copy the "IMG CODE" link from photobucket, then all you have to do is paste it here):
Fishermark
Looks like we were posting at the same time. ;)
bigdan1
the previous owner says that he had the outdrive rebuilt 3 years ago for over $1200.00 ....funny that they dint change this wire :mad:
because if those wires are only for the limit switch ....ill take great care of not going too far ;)
but in any case , where can I download the outdrive manual ?
Fishermark
The wires are not actually in the outdrive - they are part of the transom assembly.
I'm not sure of the manuals are still available in the stickey at the top of the page or not... I think they were removed. But you may take a quick look at see.
bigdan1
thing is , know nothing about boats ......
just dont want to break something when stripping
Id like to fix those two wires ,but if I have to tear down the whole thing to bare parts just for a gauge reading , i doubt it is worth it !
the good wires go to the pump control
bigdan1
fishermark , you think I woulndt have to remove whole outdrive to fix the wires ?
paultjohnson
If your trim limit switch still functions you could just splice wire to the broken ones inside the boat. Take your trim limit switch off Its the one on the port side of the drive that covers the hinge pin. See if its rusted to sh!&. and get yourself a meter and run a test thru the cut off wires from inside the boat and see if you have continuity. You may be able to jury rig it if the switch is still functional. On the starboard side is the sending unit that sends a signal to a dash gauge to indicate the position of your drive Do you even have a trim indicater on you dash ? If not dont even wory about the starboard switch. I dont think there is a way around removing the drive and bellhousing to run the wires thru the transom . If you follow the wires from the switchs on the outdrive up to the transom you will see they disappear into never never land above the u joint bellows. There are i believe 2 screws that have to be acessed to remove the gromet that holds the wires from the aft end of the transom. As I said before then you should do [or at least inspect] the whole works Bellows, water hose, check gimble bearing alingment u joints etc
bigdan1
correct me if i`m wrong ...looks like the "rear end "
is in two parts : transom & outdrive ....
can I remove the outdrive as a whole unit and check the wires at the transom ?
there seems to be four bolts holding the outdrive to the transom
is this right?
thanks again !
Dan
Howard Sterndrive
not all Mercruiser powered boats have a trim gauge.
On my boat, those wires are just hanging there.
antsmands
Looks like the tilt /trim limiter wires. Mine are rotten an I gotta replace them also. Do it while the drive is off!
Fishermark
It sounds like you pulled your engine without pulling the drive - correct? That is possible to do, and it is even possible to put the engine back in without removing the drive. But it is a real bad idea.
The outdrive is easy to remove and you need to learn how to do it as it needs to come off periodically for maintenance.
You will need to put it in forward gear and then remove the SIX nuts holding it on (not four). You will also need to remove the trim rams where they connect.
Here is a site that I haven't recommended in awhile, but since the manuals are not available... they have some good general info: General Mercruiser info
rbh
Do you have mercathode system???
bigdan1
when i bought the boat , the engine was already removed ,
I just removed the outdrive by putting it in forward gear , not that hard really , just had to take my time and do visual all the time ..... now it` siting on my bench ....
still no access to those wires ....cant even move them to see wich side they go ...I have two sensors (one on each side )
the gimbal bearing seems ok .....I push on it from outside and turn around no rubbing or hard spot at all real smooth ..... lots of grease in that area !
ID rather have the gauge workingin dash then the limiting switch .....wich is the gauge on the right or on the left (pilot view) ?
thanks againto all of you !
