laurentide
- Joined
- Jul 24, 2011
- 1,869
Re: Rough and ready '74 Starcraft Chieftan 18' rebuild
Cool man, thanks for the tips. I'll definitely give it a shot this way, as that all makes sense. They're not terrible, but they ain't straight, neither.
Really just an experiment here, as I found this stuff in my shed from a long ago wood stripping project:
My wife is a baker, so I'm mostly using parchment sheets to keep it wet (we have a lifetime supply):
I'll shoot it with the PW tomorrow evening and see what happens. Maybe nothing, maybe I won't have to paint the bottom. That would be ideal.
Just a tip on the warped wood...
Sometimes it works better if you cut the pieces you need out of the warped wood, then try to flatten it best as possible before you are ready to install...
The method to this mad concept is that if you are going to use the wood for decking, you might actually want it to have a little bit of a dip, either towards the center or the outer edges for drainage reasons, and you can cut the wood in the best possible direction for that purpose...
The other is that you might be using a much smaller piece for a bulkhead, filler, etc...and that smaller piece may be easier to "flatten" out than a whole sheet...
2? worth, minus Uncle Sam's cut=.0005?![]()
