John3
- Joined
- Jun 17, 2010
- 136
It's a newly rebuilt engine (Have about 11 hrs on it), the mechanic used my Block re-bored with new rings, bearings etc., (Rebuilt) Head, Valves, Valve Seats, New Plugs, Plug Wires, Coil. When he finished it idled rough, the mechanic said the Carb needed work & he wanted to send it out to be rebuilt. I got tired of spending money so I rebuilt it myself using the proper Mercruiser kit.
It's the original Carb, I disassembled it & soaked it in Carb Cleaner for a couple of hrs. Cleaned all the parts per instructions. Cleaned all the small holes by passing a single strand of copper wire thru them. the wire was smaller than the hole dia, didn't want to enlarge the holes.
The engine starts ok. After warm up it Idles at 600 rpm sounds a bit rough with some vibration, as though a cylinder is not doing it's fair share, vacuum fluctuates between 10 & 11 inches. At higher rpm's the Vac is steady, tops at 17.5" @ 2100 rpm.
It seems to me that with everything new it should idle smoother. Am I trying to pick the fly turds out of the pepper? If it is the carb I'll have to send it out, otherwise the mechanic should fix it under warranty.
