CharlestonFF
Thread starter- Joined
- May 3, 2013
- 14
I just bought a boat and have been working on the motor trying to get it to run better. The bulb used to go soft until I replaced all fuel lines except main line from gas tank to bulb. The motor is running a little bit better except for when you go to put it in gear the engine dies due to the rough idling. Could the timing be off? The guy I bought it from adjusted what I think is the timing thinking it was the idle. If timing is off how do you sync with the gun. Also when the motor is on the hose it runs great put it in the water the back pressure I am assuming is causing it to choke up.. I dunno starting to run out of ideas.Any suggestions would help!!!
Thanks for your time
