Rough Idle, Rich out of exhaust one fouled Carb
mrod322
1995 225 V6 j225TRXEOB
Just had cardb completely rebuilt buy local shop.
I noticed that cylinder 4 plug is fouled and the engine is smoking a lot. Also i notice some black stuff like oil coming out of the prop/lowerunit.
I premix 50-1 disconnected cables for VRO.
The jets are 2 3/4 turns. When they adjusted the carbs the power pack was only putting out 75 on the DVA even though i had spark. I replaced power pack, now i have 150 DVA reading and i have this issue.
Can a much stronger spark throw off the carb adjustmnet?
I really dont want to go back to the mechanic ( not really a straight shooter).
If i bring the mixture screws down i get an eratic head shake so i dont want to lean and blow the motor. Can I blow the motor by leaning out the mixtur screws they are only low jets...What should i do?
Benny1963
Re: Rough Idle, Rich out of exhaust one fouled Carb
yes ya can blow it quick leaning out run a compression check,
you can spray a little premix into each carb if it stalls its good if it picksup its lean .dont run it lean or it will burn a piston quick
mrod322
compression checks out fine...
