boston_jake01
- Joined
- Jun 4, 2006
- 74
I have a 89 volvo penta AQ271C I have done some work on thanks to the help from this site and the BOAT DOCTOR.... my question is the engine sems to run good at about 1300 or above, but when I try to lower the throttle to idle around 800 - 900 it runs really rough and then stalls. Ithought it might be a vacuum leak and placed my had over the carb and it smooth out. I did a vacuum test thru the carb vucuum port for the choke pull off and it registered at 20 and would lower to about 13 or so when it ran rough.
any thoughts? does it seem like a vacuum leak and if so where would the leak come from, I figured it can only be carb and intake manifold.
Thanks
Thanks
