Hi. Trying to help a friend with a Yamaha E75BMHD, 2006. It has a rough idle. When the spark plug of the bottom cylinder is taken out, the motor keep running the same. Unlike when the same thing is made with the other two sparks (get lot worst). It was made with a spark tester. The ignition is firing to the three sparks. The carburetor of the bottom cylinder was taken out and cleaned. Water and dirt was found on it as in the fuel tank. (They just bought this used boat). This boat was left like 5 months in the in salt water by the previous owner. We could not measure the pressure at this point.
Is it true that this motors has a sensor that will disable one of the cylinders, under certain circumstances?
Any remarks pinpointing possible work that will have to be done will be greatly appreciated.
Thanks
Thanks
