Re: Rough running 20 hp Mercury
Hey guys...sorry to change the topic but i own the exact same motor and seem to be running into many problems....about two or three years ago my boat with the '74 mer 20 Hp on it sank. it was only submerged for a few hours and upon retrieval i was able to get the motor to start up with ease. since then i havent used the boat and the motor has developed problems....my first problem is that the impellar wont "Pee". I recently installed a new impellar and seals but came out with no luck. the motor will not circulate water. my second problem is that the motor will not advance to full throttle... I was using the motor (without water circulation
for one weekend, for only about two or three minutes at a time and the next weekend when i went to try it the motor would only give me half throttle
. I have checked the linkage and made sure the gas tank valve was open...Any suggestions would be greatly apreciated seeing as i would really like to use this new motor on my new hydrostream voodoo mini this summer.....
P.S this motor uses a standard Mercontrol remote system.
