76SeaRay
- Joined
- Aug 24, 2017
- 1,071
Now that my new transom is in and I am starting on the stringers, I need to know for sure where my front motor mounts will land before putting in the new stringers and floor. This boat originally had an OMC Windsor 351 in it with an OMC stringer drive so want to be sure the 5.7L Alpha One is going to fit correctly or make adjustments as I rebuild the stringers in that area. So, here is what I am thinking I will do to rough in the motor mount locations (looking for feedback on the idea).
My outdrive is completely disassembled for repainting and rebuild, however, the old gimbal bearing is still in the gimbal housing. I plan to temporarily mount the inner transom plate and the gimbal housing (without reassembling it) to the transom. Then, lift the engine into place on the inner transom plate rear mounts and with the motor mounts attached to the engine. Using the alignment procedure and the old gimbal bearing, align the engine close to what it should be. I will have the front mounts adjusted to the center of their vertical travel for height. In theory, I would then have the proper stringer/floor mount location based upon the bottom of the engine mounts. That would allow me to rebuild the stringers in the engine "box" location (stringers closest to the center of the boat do not run continuous to the front of the boat but rather form a box). Once the engine "box" is rebuilt and I know the engine fits with the appropriate clearance, I would then have reference points for the rest of the stringers.
So, does this approach have any pitfalls for getting the engine mount locations correct using a rough engine alignment as I described with a mostly disassembled gimbal housing?
Thanks....
Thanks....
