rounding over stringers, etc
ok, have router in hand, is 1/4" radius enough for both CSM and 1708, or should I go to 3/8"?
Georgesalmon
Re: rounding over stringers, etc
1/4 is enough, you just need to break the sharp edges. Larger is easier to roll over though.
62cruiserinc
I wouldn't go over 1/4" radius. Even with the 1/4" radius you will lose 1/2" of flat width on top of the stringer (2 x 1/4"). Depending on the width of the stringer, this could be significant.
Steve
Cadwelder
Personally to me it depends on what part of the stringer you're doing. If it's the flat top that your deck will lay down on I don't round them at all, due to loosing the surface area to attach the deck to.
I glass in the stringer right up to the top and trim the glass flush, then brush on some epoxy on the top edge before setting the deck down on it and attaching it.
Now if it's an exposed stringer then yep round her off with the 3/8" as it'll make the cloth roll over it much better.
CW
