RPM and Timing on 2 Cylinder Mercs
mmf
I don't have a 2 cylinder RPM guage but I do have an automotive Tach/Dwell meter but the lowest cylinders it will go is 4 cylinders. Is it possible to use it and divide the 4 cylinder reading by 2 or something? Anyone else done this?
Thanks
daveswaves
Ensign
Re: RPM and Timing on 2 Cylinder Mercs
Thanks
You don't say whether your ignition is points coil or cdi type coil, the dwell meters are designed to run on switched 12V. If you can get a reading at all
the rpm should be correct when set on 4 cyl as the 2 stroke fires twice for every once on the four stroke.
mmf
I guess I forgot about the type of ignition system which is CDI (Thunderbolt) around 1973 with the maker module (orange) under the flywheel. I wonder if someone makes an inductive pickup tach that will read off a coil like a timing light?
7920hpMercury
Another option I have had good luck with is a Tiny Tach.
Get the Tiny Tach that reads for 180 degrees or 2 sparks per revolution. These work great for a 2 cylinder 2 stroke outboard. Might have gone up, but I paid $25 a couple of years ago. They use these on rental lawn mowers and such for hours maintenance plus they have a digital readout for rpms's. You can also leave it installed if you want to.
