rpm drop with load
markshop
About how much drop in max rpm will there be from a light load to a heavy load in a pontoon boat. My boat with just me in it will run 5800rpm. The safe range for my motor is 5000 to 5500. Say from 1 to 6 passengers. Thanks.
Bob_VT
Re: rpm drop with load
RPM drop is not as predictable as we like. If you are concerned with maintaining WOT at max RPMS (Pretty gas costly) then a differant pitch prop is in order. Why not just load up the boat and see how it reacts before investing in a prop.<br /><br />Bob
markshop
The boat is new and the dealer is willing to just exchange props. I will seldom have more than 4 people on board.
ODDD1
Mark, the dealer is doing alright by you...5800 [300 over max] with just you is ok..by the time you get the boat loaded the way you want to use it those 300 rpm's will dissappear....gear weight, a little crud on the toons, and the most important, air quality...right now we got horsepower air,cold an dry...in july you wont be making this power, an your rpms will drop even more.
SeaDawg
Yea, I would stay with the prop that is on the toon. With one or two more persons, you will not overrev at WOT.
markshop
Thanks guys. I trust your opinions. I will wait and leave this prop on and see what i have later this summer when its warmer and at least have a load of 4 or 6 people. Thanks again. You guys are the pros. Iam just new to this.
