RPM gauge
CapJB
I have a 5.7GS in a 2000 Sundowner which is new to me and the RPM gauge is not working.Any ideas on where to start looking would be appreciated
Use a handheld Tach, and connect to the input lead (which is a gray wire) on the Tach to see if you get a reading when the motor is running.
If you get a reading then check connections on the gauge and if good, you need a new gauge
If there is no reading then trace the gray wire back to the (-) side of the coil
