FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Engine (1997 112hp) cranks with no problem, but the RPMs are setting at 8500-9000. The engine sounds like it is idling normal. After running for awhile in water, the RPMs drop back to normal. Mr D
Welcome to iboats. <br /><br />I assume you mean 850 to 900. <br /><br />Check your throttle cable adjustment to make sure it's bringing the motor all the way back down to idle. Sounds to me like it isn't.
I hope it is a bad Tach. I hate to just keep buying until I get it right.<br /> I will have to get back with information later on this evening. work till 3:00.
Got the info from Tach...it is a stock no name. The numbers run from 0-8. I guessed 9000 because the red indicator goes past the 8. At the bottom of the Tach it says RPM x1000. That's all I have and I will check the stator and the throttle cable. I'll buy a Tach this weekend. I'll let you know! Thanks
