bob johnson
- Joined
- Feb 25, 2009
- 4,306
soooo i am having rpm issues...havent quite nailed it down Ive been running a 15 X15 prop...its in good condition, and so while there were things to check out on the motor, id thought Id try a different prop anyway. I had a 15 X17 stainless steel prop.... i figured it might be a wash, it was stainelss the other one is aluminum. launch the boat at the ramp , push off and put it in reverse...the boat heads back into the ramp!...waaaa... try it again...drives me back into the ramp.... i put it in forward and sure enough Im backing up...... the prop is a counter rotating prop! I never knew that spare motor was a counter rotating motor...( i bought it for the powerhead....) sooo im in the water and dont want to load back up...so i throw the shifter in reverse and away i go...FORWARD...... so Im thinking....am I going to damage anything?....im guessing the only thing that previously preventing from rev-ing the boat in reverse was the gallon and gallons of water that would try to climb into the back of the boat! does the clutch dog or the reverse gear take a SET? in anyway.... maybe it was my imagination but after running up to 3000 rpm seemingly ok eventually I thought it felt a little funny...plus it SEEMED like the steering was harder.....anyone ever do this before?..... eventually i pulled over to the bank and put my spare prop on.... wondering is there a bad side to running a regular motor at high rpms in reverse?
