BAron Sportsman
Thread starter- Joined
- Apr 21, 2011
- 17
V6 Mercruiser Cruiser RPM.
While I know I'm probably about to get shot down in flames with my question but I've just fitted a V6 Mercruiser to my boat and wondering what an optimum cruise RPM for it would be. The con I have for my own question in my head is that every boat is different, length, weight, material etc so I guess my question becomes a bit blind with possible answers.
Sensibly boat engines do a lot more work in a boat to the same engine in a car, therefore I've always been one to set RPM and accept speed or even economy for that matter. I think it's a safer and kinder way to treat it for long term wear and reliability.
Is there a sweet spot recommended for cruise RPM. Merc don't seem to want to answer my question so I thought I'd throw it around with you fine folk.
Boat is 5.5 meters and I believe will weigh around 1400kgs give or take 50. (Yes I do really need to run it over a bridge and get it weighed now I've changed the engine).
Engine is a 2003, 4.3 190hp merc V6 coupled to an Alpha 1, gen two+. Prop is Solas E3x14.8x19R.
I can find WOT answers everywhere but is there an optimum cruise RPM for this setup. I've only done one water trial so far with the new engine and while it appears to go boofing hard up top (No answers recorded on this part yet as I've not opened it right up for the first trial), it felt to me that the engine sounded happiest at around a lazy 2800/2900 rpm. I wouldn't consider up to around 3400 from time to time would see any major increase in engine wear other than chewing a bit more fuel.
I am rather kind on boat engines but at the same time a long haul fishing spot would be nicer if I got there a bit quicker without taking half a day while also not killing an engine. It certainly goes a lot harder and different to the little 2lt Volvo it replaced and a whole heap new learning.
So I guess my question is: Is 2800-3400rpm considered a sweet range or is the range broader than this forgetting fuel economy? Or better yet is there a recommended cruise RPM "Range"?
Thank you once again fine people.
Cheers
Cheers
