RPM's suddenly climbing boat slowing down after hard impact on waves
mtb_prodigy
Ive got a 96 bayliner 5.7L Mercruiser and its been giving me problems the last couple times I took it out. I was in the ocean and it got a little rough. This happened on two separate occasions. After going over a wave theres a hard smack when the bow comes back down. As soon as we hit the water the rpms shot up (from 2800 to 3800) but the boat slowed down. I dropped the RPM's back down to idle, hit the throttle again and all was fine. Im worried its the coupler. Any ideas?
alldodge
The prop may have ventilated, or came out of gear, don't see a coupler doing that
JackBronson
If the stern rose up enough (which you may not have picked up on, being focused on what the bow was doing) I'd say it was cavitation.
tpenfield
Sounds like you 'caught some air' :D :thumb: the prop/engine goes crazy but does nothing and then finally grabs once you throttle back.
The folks running the go-fast boats through the rough stuff usually 'chop' the throttle back for a split second once they feel they are airborne.
You are just going to have to take some lessons from those guys :D
achris
More fish than mountain goat
Sounds like you 'aerated' your prop. Either trim in a bit or change to a prop that's more tolerant to a bit of air in the blades. Or slow down. Not sure where you are, but if all you have done is rivers or lakes, the ocean is a whole different world of hurt. Slow down a bit until you get an understanding of what you're up against. And getting 'a bit rough' is what the ocean is really good at... :D
Chris.......
I agree, you ventilated (prop came out of water, then when it re-entered, it aerated the water)
many of the go-fast boats have a rev-limiter to "snuff" the ignition for a few seconds when the motors become suddenly unloaded by getting airborne. this is to keep the drives from grenading
