my1stboat1
Thread starter- Joined
- May 31, 2010
- 307
Hey richard, Recieved your Pump today, Installed on the boat and check all operation, works fantastic... Lefted the engine up for an hour and had no leakdown.... I was wondering if i could offer a small piece of advise on the instructions for the reseal kit you offer... The instructions are fantastic... But maybe you could write on how to properly fill the Shock Ram... I noticed today that after installed the pump and valve body it wouldnt go into TRIM mode and thats cause the shock wouldnt fully compress... I realized that i had filled the shot to much with oil and that when the motor bottomed out at full trim, The psi became so great in the trim ram it actually popped the cover off the ram... I was lucky enough to get the cover to screw back into place and take alittle oil out.. IT Now works great... But maybe others who purchase your kit in the future could be told how to properly fill the rams and with what type of fluid belongs in it.. I went to west marine today and spent 30 minutes getting the correct trim pump oil... I spent over 400 dollars rebuilding the tilt/trim cylinders and wanted to make sure the correct oil was in the system... Again I thank you and lefted you great feedback... And hope i did not upset you with the advise...
Mike C
Mike C
