RTV or no?
PowerAddict
should I use RTV on the intake to the block on a 140hp merc?? The service manual doesn't mention it so I'm assuming not, but just want to ask.
Rob454
Re: RTV or no?
Outboard? no the gasket should be sufficient. if you must use RTV silicone make sure you put it on thin thin. I usually take a little bit and then I smear it around with my fingers ( basically rub your thumb and forefinger together and the gasket and silicone is between fingers) this way its thin thin and when you tighten it up it doesnt squish out all over
Rob
