Rubberized bullet connectors
maremsk1
Hello. Does anyone know where to find rubberized bullet connectors like the ones used on a BF-15. I want to replace mine. (all corroded). Been all over the net and cant find them??
Skidz
Re: Rubberized bullet connectors
Marine grade connectors would be best, but barring that, I wonder if some good car audio connectors might be a good replacement?
Star
Those connectors ar made of brass or copper and can be easily cleaned with scotch bright.
robert graham
I have used the metal connectors and slide a section of clear plastic tubing over the connection with some grease to keep out moisture. That way you can actually see and inspect the connection for corrosion. But the actual rubberized bullet connections, I don't know where you might find those...
FunInDuhSun
A well-water installation company.
They use 'em to wire submersible well pumps.
