StingRay_90V4
- Joined
- Aug 26, 2014
- 155
Thanks to everyone who has given me advise so far. I seem to have my new boat working really well so far except for two last small issues I was wondering if anyone could help me out trying to figure them out. The motor runs great. And feels strong. The boat planes really well and I couldn't really ask for too much more top speed I don't think. It will always hit 38mph at the low of top speed if the lake is really rough and the weather is windy. Any other day it will always hit 39mph and sometimes hit 40mph when the laske is calm. It is doing about 5500-5700rpm at wot. Which is great. My questions are ,
1. The pump bulb from the gas tank seems to loosen up from time to time and the motor seems to loose prime on the gas tank. And will seem too loose fuel and power untill I pump the bulb and then it takes off and all is good for awhile. Sometimes only 5-10 minutes. Sometimes for the rest of the tamk of fuel. Any idea what could cause the bulb to loose pressure ?
2. When the engine first starts. It starts farily easily. And idles great. But when you put it in reverse or even forward. It will sputter and die. Even if you try to use the nuteral rev/chole lever. As soon as it goes to rev up at all it will just die right away. But yet it will start great and idle perfect no problems if at all and not stall at all if you just let it idle for like say 4 minutes. Then , it will rev no problem at all. Instintly revs, and will go into forward or reverse with zero issues. It just seems to be a issue for the first few minutes untuill it warms up part way . Is there something that needs to be adjusted to allow it to take fuel while it is just started and warming up ? It is great and runs strong once it is runnimg for 5 minutes tops.
Thanks for any help !
