Run up my 1977 470 today and...
Rake722
She ran great !
I fitted a Faria water tem switch thats rated at 217 F US Resistance.
I then connected tot he guage that was green / red indicator - no temps witten on it.
After 10 mins on the muffs she for to the red but inly just in it. Should I worry ?
I have a faria chesapeake black going in next week with US resistance too. I wonder if the existing guage is Euro resistance...
I have dropped the idle from 1200 rpm to 800 rpm - too low ?
How does the old girl sound to you guys ?
The trim stopped working but I had had the hoses disconnected from the cylinders last week so probably need refilling.
Many thanks for opinions.
Will add video of the MC1 Leg next
Ron.
Failproof
Re: Run up my 1977 470 today and...
Sounds good. Engine should not be ran with drive trimmed up so high. Damage to the ujoints and sideload/stress on input seal,carrier, and all.
Rake722
Thanks.
Any checks I should do now that it has been run up fuy trimmed ? Have I damaged any thing ?
stonyloam
Idle in forward gear 650-700 RPM. In the red at idle on muffs is probably not good. Need to find out the actual temperature you are running. When was the impeller changed last?
Rake722
Thanks Terry, I was hoping you'd chime in here.
Impeller change last week.
Heat exchanger cleaned and tested.
I'll have to try to get hold aof an IR thermometer - beg borrow steal job today.
Will report back.
Ron.
Rake722
All good. Fitted us resistance guage and she sits under 175 happily on muffs.
Must have been the guage / sender combo.
Found another issue - only one trim cylinder works. Fluid through but it don't shift. One is doing the work of the other.
Any ideas or new thread time ?
Thanks again all
Ron
