Re: Runaway Revs!! J48ESLEDC..UPDATE>>HELP!!
I just posted this on another post, but thought I would share here too since it was basically the same issue.
Sure enough it was trying to eat a screw. It was one of the four screws that holds the carb plate to the carbs.
I did some surgery and extracted it with a long pair of needle nose. The throttle was open with the bolt there.
Once I removed it, it would close properly. I looked for any other parts in there, none that I could see. I cranked it up and it ran fine. Although it isn't real tight against the carbs, I am thinking that is how I am losing a little bit of fuel. If it isn't all the way flush against the carb plate, then fuel can escape there I suppose.
Now here is the big question:
How in the world does something like that get unscrewed?
I tried putting the screw back in , but guess what, there were no more threads left in the hole where the screw was at. (Guess that is why it came out huh?) I also looked at the other screws and they were fine except one, and it was rather loose. I tightened it up some, but it was kinda stripped , so I got it as tight as I could for now. Will have to do something with it too I suppose.
So what do I do now, have someone rethread the hole? Helicoil?
What can I do with this or should I have a mechanic redrill the hole or have a new plate put on?
