Running 2 batteries from 1 alternator
jd_smith
Hello everybody, <br /><br />Just recently repowered with an '86 Johnson 140, my question is, what is the best way to hook up a second battery and have the motor charge it. I have heard that it is not good to have 2 batteries running off the stock alternator, is this true? Are there special alternators available for this motor that would accomplish this feat? <br /><br />Once again thanks for the info!
MajBach
Re: Running 2 batteries from 1 alternator
When I purchased my DC boat a few years back, I was dismayed to learn that the dealer did not/would not wire my trolling motor battery to the outboard. Even when I asked him to do so via an isolation switch, he did not know how to[properly] (Canada's largest Sylvan dealer to boot). He claimed that the 'norm' was to charge deep cycle batteries seperately - usually involving removing them from the boat.<br />I think this is a ridiculous proposition. Although I have heard that deep cycles should be charged slowly, this is something that can be overcome with a resitor in series with the outboard. But why bother? In the past, I have frequently removed my deep cycle batteries from my boat and used them in my car for the winter. I have found their reserve capacity of great use on many occassions. Despite how quickly a car drains and recharges a battery, the last deep cycle I used lasted 7 years with this type of routine; summer in the boat, winter in the car. I for one feel that even if it is a fluke that my deep cycle batteries lasted unusually long being misused, I would much rather pay the extra dollars to replace a deep cycle twice as frequently as normal by charging them quickly via my outbaord motor. I'll never have a weekend again where my trolling motor batteries die before the trip is over.<br />So to answer your question, use an isolater switch to charge your two batteries individually or together. I have done this now for 4 years in my present boat on the same original batteries. The isolater also allows a good starter backup if your main happens to drain (my radio will suck it dry if I forget to shut the batteries of at the end of a trip). Just remember to make sure your isolator is set to not use both batteries to start your outboard except in the above situation.<br />MajBach
Solittle
You wrote - - "Just recently repowered with an '86 Johnson 140, my question is, what is the best way to hook up a second battery and have the motor charge it." - - - Most outboard alternators simply do not put out enough juice to charge an undercharged batery unless you run it for many hours and do not use accessories. Best to start out with fully charged batteries. Your motor should keep it topped off. <br /><br />How often have we seen someone jump a dead battery at the ramp and take off for the day and hope they are carrying jumper cables and find someone to get a jump from for the trip back to the ramp.
rodbolt
hello<br /> there are many ways to do this. from just tying the positives and negative together to swicthes and isolators. what is your goal here? I just run two in parrelell on my 85 120. only because it sits in the water all the time as I dont have a trailer and I like to keep the bilge pump working.<br /> good luck and post back what your looking to do :)
jd_smith
Thank you all for the information it will help me a lot. I am trying to equip the boat for some night fishing with plenty of light, I just want to make sure that I don't drain the battery. I would like to run the second battery to run lights, fish finder, bilge, etc... Looks like its a possibility.<br /><br />Thanks again!<br /><br />Justin
MajBach
If you want to use a second battery for a different purpose ( such as lights etc ) you DEFINATELY want an isolator switch. If you hook them in parallel, when one is dead, so is the other.
