alley mechanic
Thread starter- Joined
- Apr 15, 2011
- 100
hello, I am in the process of resealing head and replacing o rings and thermostat seals on a 98 115 60 degree evenrude, the factory manuel says to run a one 16th bead around the water passages , well I have the oval passages and the passages with two round holes close to each other do you run a bead around each of the two round holes or just run a bead around both holes at same time, also omc ran some rtv in the oring groove the manuel says to use some triple guard grease to hold o ring in place , also. there is some small hole near head bolt on each head that omc put a glob of rtv in to plug it what was the hole for . heads have never been off I am the original owner. thank you.
alley mechanic
alley mechanic
