I have a 1984 Mercury Black max V6 150....
The problem I'm having is I'm getting an over heating alarm at high rpm and wot and if I'm under 30mph I can ride all day without the overheating alarm coming on...but once I get it pass 30mph and within a minute the over heating alarm sound off and I have to back of the throttle and it will go off......I change out the impeller and gaskets and still have the same problem. I remove the T- stat housing and found that there is no t-stat in it and is gone.....but I been running like that for over 3 years now without any problems at all until now....didn't know I didn't have any t-stat....got to get some now....could it be the problem or not. the water seem to be coming out ok from the tale tale..........I don't know but where is the Poppet valve on my motor....could it be that and if it is or seem to be it.... where is it located on the motor? I back flush out the motor and the water seem to flow through ok without any restriction. I inspected the spark plugs and is ok ........I haven't done an compression test but will do that too...........any ideas what could be the problem of my over heating situation......any suggestion is ok.....thanks.
