'84 1.6l OMC Sea Drive (4cyl. 115hp Crossflow)<br /><br />One of many issues discovered today on my pair of Sea Drives!<br /><br />Here we go............<br /><br />Reman'd power installed last year, with typical bells and whistles (rebuilt carbs with upsized idle air jets to go along with Boyseen power reeds, new recirc valves, new 4 wire VRO, new p-packs, coils, new s-plugs and wires, new voltage regulator, new water pump kit, t-stats, hoses, etc,)<br /><br />Ran like a champ @ temp last year, although RPM appeared a little low (4500 - 5000), which after much discussion attributed to bad tach, bought tiny tach to troubleshoot but didn't get that far. <br /><br />Today fired her up, took a few tries but attributted that to fogging last year, once she was up and running ran and sounded well on the muffs, tell tale strong, (but cold?), water pressure OK for muffs @ 5 psi plus. After a few minutes got hot horn. Heads (both) running hot by touch, Infared pyromter acting flaky (figures!) but also indicated hot (160+). Did have lower units off but thought re-install went OK (good tell tale flow). Also checked spark and compression. Spark good compression @ 120 - 125 on all $4.<br /><br />We seem to have repeated overheat issues with the pair of Sea Drives we have. Last year,other motor ran hot on the muffs, re-installed new stats and was OK, but fried voltage reg, replaced this year and ran OK on muffs but found # 3 cyliner with low compression (topic of another post).<br /><br />Frustrated with my money pit and tried of making mistakes. Please help!!!!!!!!!!!!
