Running issues with Force 90HP, year 1991
nathan.
hello, can anyone help with running issues I am having with my Force 90HP, 3 cylinder, 2 stroke outboard year 1991. I have recently bought this boat and it has not run correctly since I’ve had it. The outboard has restricted performance and occasionally cuts out at lower throttle & I am unable to reach full throttle as the outboard again cuts out like it is not getting enough fuel. When carb 3 is covered by hand the engine perforce improves slightly but still not running correctly. I have replaced: all 3 spark plugs, Reed valves, 2 ignition coils (due to a misfire) & fuel pump diaphragm. The fuel has been checked and mixed correctly at 50:1. The carb floats & jets have been checked and are all okay. I have carried out a compression test on each cylinder and am getting a good reading of 120 psi on each. Fuel lines are in good condition and not blocked. I’ve tried running it from a separate petrol can but still no improvement. Can anyone advise the next best area to target? Thank you.
Nathan.
The Force power
Nathan.
I would start by inspecting all the wire terminals on the terminal-strip by gently pulling on the wires (they tend to break under the shrink-wrap)
After you have inspected/repaired the wiring, follow the instructions carefully and DON'T skip ANY steps. Welcome & keep us posted.
1.Disconnect the ball link to the carb cam at the timing tower. Disconnecting at the cam risks bending the cam. Move the cam away from the carb roller.
2. Loosen the screw(s) on the aluminum tie bar and let all carbs close completely, then tighten again.
3. Set the cam so that the scribed line is pointing directly at the black roller on the carb lever. If the cam has two closely spaced lines, set the black roller directly between them.
4. The black roller is held with an offset screw and nut. Loosen the nut and turn the screw until the black roller JUST touches the cam. Tighten the nut and re-attach the ball link maintaining the scribed line at the roller.
5. Adjust the ball link so that at full throttle the bottom carb butterfly opens substantially horizontally. Adjust the aluminum tie bar so all carb butterflies open equally at full throttle. They need not be perfect but should be rather close to horizontal for best performance.
6. Adjust timing to 28 degrees before top dead center at full throttle.
7. Adjust idle speed to 700-750 RPM in the water in forward gear. Do this with the screw on the bottom of the timing tower. Loosen the locknut and adjust. Screwing in increases idle speed. Do this in small increments and let the engine rev and adjust itself before the next adjustment. A little goes a long way here. When correct, tighten the nut. Note that the scribed line on the roller will now be (usually) below the black roller a bit.
8. NOW we adjust the mixture on the carbs. Set all low speed needles to about 1 1/4 turns out from lightly seated. Do not force as this will damage either the needles or the seats.
8A. With the engine idling in neutral, turn each the needles in equally about 1/8 turn at a time. Give the engine a couple of seconds between each adjustment to stabilize. Adjust until the engine either "sags" or stalls. Note this setting.
8B. Now go the opposite direction. Adjust until the engine runs rough, burbles, or stalls. Note this setting.
8C. Set all needles to the average between the two settings: That is, for example, if it stalled at 3/4 turn out and burbled at 1 1/4 out then set all needles to 1 turn out.
8D. Readjust idle speed to 700-750 RPM.
9. Take the boat out on the water and do a "hole shot"--Full throttle acceleration from a stop. If the engine "sags" then recovers and picks-up it is too lean. Open the needles about 1/16 turn at a time until the engine accelerates with no hesitation.
If the engine sputters or coughs or burbles, then clears itself and accelerates, it is too rich. Close the needles about 1/16 turn at a time until the engine accelerates smoothly.
10. I can NOT stress this enough! NEVER set the low speed needles less that 1 turns out no matter how poor the idle or acceleration. To do so will run the engine too lean and detonation and melted pistons at or near full throttle operation will result.
nathan.
Thank you for the response. I will try this and come back to you
