CV16
Thread starter- Joined
- Aug 30, 2007
- 445
OK, on my dads boat, we run a 15hp trolling motor. We usually head out a few hours before sun up. He wants me to run the power for the running lights to the battery for the little motor instead of the main battery. He wants to be sure the main battery doesn't drain from the use. What I'm thinking is to put in a toggle switch or two so we can switch between the two batteries depending on which motor we are running. If I were to just run a power wire up to the fuse panel and put a toggle switch for each power wire, do you guys see any problems we might have? I'm not much into electrical stuff, that's why I'm asking, but I think it'll work.
