Running motor
SweeperForce
Is there any harm that can come from running the motor in a tub of water without a prop. I wan't to run all the gas out as part of my winterization.
Tom
my1stboat1
Re: Running motor
they sell test wheels for running the engine under load...
jerryjerry05
Re: Running motor
Running the gas out will allow the cylinders to run DRY:no oil.It will run out from the top down.So the top 2-3 will be running dry.
It might score the cylinders.
If you add fuel stabilizer and don't want it to set with fuel in it, should undo the float bowl bolts and drain them.J
wickware
Re: Running motor
I know the feeling when you planned on going out again but time w/n allow. I have pulled my 1970?s 35 HP Chrysler?s glass fuel bowl to clear it in earlier years (to shorten the run process in a barrel). Since using StaBil the last 5-7 years, I have not been concerned about running it dry and have not had a problem. Good Luck! JOW
emoney
Re: Running motor
I keep telling you guys just to move to Florida and you won't have all
these issues. Sheesh.....some people never listen.:p;)
