I took the one-piece rubber overmolded gasket and laid it on my cast iron table saw top (flattest thing I have available), and it is not flat. It will rock a bit across one of the diagonals. That's an issue that torquing the 4 little pump hold-down capscrews may not be able to solve. Next, I did a trial installation of the 3 gasket system using alignment pins, and it is a VERY close fit, with no perceptible movement in any of the gaskets or the housing at all. I just don't know if the steel bottom gasket (not the plate) needs to be sealed to the drive mounting surface. In his video,
achris has a paper gasket with a "tombstone" cutout, not the "outline" steel gasket I show in my photo above.
Since I chose to use the one-piece rubber overmolded gasket also included with the kit, and if it does not sit perfectly flush after torquing the pump screws, I suppose it could leak air in normal operation, leading to inefficient pumping, and also leak water when test pressurizing the drive outlet. This may be the source of the 180F temp vs 160F design temp that I was seeing last year when on the water. Also, when running on muffs days ago, I saw that 180F temperature. In part B of his videos,
achris mentions that this can cause overheating.
If the one-piece rubber overmolded gasket can cause problems, why doesn't Mercury have a service bulletin out on this, telling people to discontinue use? (Maybe they do, but it is only for their dealer network - does anyone know?) I think I am like so many others who just want to do their own engine/drive maintenance, and not have to depend on dealers. I considered having someone do this a month before the 4th of July weekend, but all the local marinas quoted me times after the 4th, so I did it myself. Even bought my own sterndrive jack from Boatstands, because I will have to do this for my boat every three years. Just want to get it out on the water while it's still summer!
