i386
- Joined
- Aug 24, 2004
- 3,548
Today I'm back at it with the 33HP Evinrude. I was hoping to get the high speed jet dialed in today but that was not meant to be.
Got her on the lake. Not enough power to plane at all. Top cylinder is cold bottom one is warm. Remove the top plug wire and it diesn't run any different. Remove the bottom one and it won't run at all. Ok Fine. Limp back to the ramp and go back home. 5 minute drive. Remove the plugs and spark test both cylinders. Both look good. Try to run it in a bucket. Reluctantly starts. Pulling the plug wires one at a time reveals it will now run on the top one but die if I try to make it run on the bottom one. Yes you read that right. Completely opposite problem than I had on the water.
Motor is hard to start today and backfires out the exhaust a couple times before it decides to fires up and run. Runs smooth once it's going. Too smooth. It's hard for me to tell when it's only running on one when it starts up on one.
Points and condensers are brand new.
