troutstalker2
Thread starter- Joined
- Aug 10, 2010
- 5
I friend gave me a 1986 25 hp johnson ducks unlimited edition motor, took it out for a spin and running great and after about ten minutes it died. I was able to start it but was bogging very badly. Did a compression check, about 105 in both cylinders. I started it at home and there was spark to both cylinders. I removed the plug wire from the top cylinder with no change to the running of the motor. Replaced the top plug wire and removed the bottom and it dies immediatly. I guess its running on the bottom cylinder only. the motor has not been run for four years. Were do I go from here?
Any help will be appreciated, David
