89wrangler
Thread starter- Joined
- Feb 22, 2011
- 17
I have 1988 85hp on a Bayliner 17' Trophy Bass boat. Boat will start fine once you squeeze the primer bulb a couple of time, idle fine, and run great up to a little over 3300 RPM and then will start running out of gas and slow down until it dies if you leave the throttle open. If you back the throttle off, it will idle. Then squeezing the primer bulb I noticed it is not full. Give it a couple of squeezes and will run great up to about the 3300 RPM mark again. I have so far,
checked fuel lines for blockage/leakage
checked to make sure vent was not blocked
change fuel pump diaphragm
new plugs
going to clean carbs this evening.
Any other suggestions on what may be causing this scenario? Thanks!
new plugs
