2stroke1971
- Joined
- Nov 8, 2009
- 210
LONG story short: Bought an old Bayliner, an 84 with the volvo AQ125 motor. Supposedly ran.
Would only backfire for me at first.
*Replaced timing belt because the old one was crappy, and it was off by two teeth.
*Rebuilt Seawater pump--had a blown seal and bad bushing and cross piece.
Still, just a backfire, so I checked compression.
I had 150 pounds on 1,2 and 3 but zero compression on 4.
Pulled head. Broken valve on number 4..(burnt and crumbled)
*Rebuilt the head, all new exhaust valves...one was broken, the other 3 were cracked (burnt)
Cranking and cranking...nothing. its not even trying.
Good spark on all new plugs.
wiring order correct.
double checked engine timing, correct.
Put timing light on it, under cranking I have it set to about 6 btdc, although it drifts just a bit as its cranking.
I dont think fuel is making it to the cylinders. plugs seemed dry. And cranking it with plugs out, I would have expected it to be blowing some vapor, right?
There was a lot of gas pooled up in the intake when I took the carb off...flooded I guess, but Wouldnt it get sucked into the cylinders?
I put my palm against the intake hole as best I could with the studs sticking out, and it seemed to suck in pretty well.
Ive had the carb apart, it was clean, no obvious problems.
Ive worn the battery down three times. Not so much as a cough.
It has electronic ignition.
Im running out of energy.
Any ideas on what to do next? Why would it not vaporize fuel, or pull it in? The puddle in the intake is from the accel pump I imagine, as I was pumping it here and there through the 20 minutes of cranking.
