Running out of water?
starsnstripers
72 OMC Stringer - There is a garden hose fitting on the gimble. And the drive suction screen inlet. Now, do you or can you just hook a hose to the fitting and run? What about the drive water pump? Or is there a certain "muff" to use on the OMC ? Not like the Merc. ear muffs. Is the hose attachment just to flush or? thanks, hope this makes sense.
QC
Re: Running out of water?
Yes, you can run simply from the hose connection. The drive water pump will still have water to it. No need to use a muff.
