New member, longtime lurker. I've been battling my mercruiser for the last year and I'm running out of options..
I've got a 2588 seamaster with a 2000 mercruiser 5.7 EFI, TBI serial # 0m034934. Engine has 450 hours.
So for the last year I have been experiencing all kinds of issues after a relatively long run I would say after 30 to 50 minutes of 3/4 throttle or cruising speed around 25mph. Usually I will hear a pop or backfire then shortly after I will have really rough runability. The best way I can describe it rough idle, surging, hissing or sucking sound from the TBI. Occasionally the boat will not re- start immediately but after a long cooldown it will fire right back up and good for another run. Once it did a full instant shutdown at cruising speed.
I have also found when it will not restart I have pulled the fuel filter off and found the canister to be 1/2 empty. I have topped the filter back off and been back to the races.
So the boat had bees at the shop 5 times and they come up with something to fix but never complelty solved the issue. I've had 2 coils, plugs, wires, cap, rotor, 3 fuel filters, redone the fuel filter housing, the tps, had the floor taken out of the boat for inspection and adding another vent line. Checked and cleaned the pickup, fuel pressure regulator, new manifolds and risers. Compression test done all within the last year.
I was told the fuel pressure was good,spec is 30psi from what I gathered. but I got my own guage set up to verify and I was reading 43psi all day??
I also noticed today that my engine temp never got much more than 140. I was messing with the engine and I noticed that even when warm the throtttle body would never open up when I opened the throttle. That doesn't seem right to me?? With the engine off the throttle body would open up with the throttle lever.
I did a slow motion video of the spray pattern and it looked very uniform and cone shaped
Hopefully one of you guys can help me out and give me a direction!
