running rough after impellar change
changed the impellar on my 03 115 ficht recently. before I changed it seemed to run smooth, just didn't pee very well. changed the impellar and it seems like a "messy pee spray". not a good steady stream. also, when running on plane, it seems like a constant growling noise. before I changed it, the noise was a smoother higher pitched growl(sounded good). sounds like something is not right. any ideas?
gm280
If your pee stream isn't right, and you just replaced the impeller, sounds like you might have not installed the water tube correctly. But I have to admit, that is merely a guess. I would go back in and make sure it was installed properly. But that is just me. :noidea:
