renegade15
Thread starter- Joined
- Mar 29, 2009
- 99
I have a 1990 70hp johnson on a renegade flats boat that runs rough when you start to throttle up, intermittently. My neighbor is a car mechanic and he said it sounds like one of the carb floats is stuck and causing that cylinder to run real lean. It sounds like a 2-stroke dirt bike until you come back to idle, then it is nice and smooth. Of course if you turn it off and start it back up it runs fine. Pumping primer bulb does nothing and I just put new plugs and wires in. Anything else it could be? I was going to rebuild the carbs and noticed I can get the sierra kits for a little less than half of the evinrude/johnson rebuild kit, is the factory original really worth double? Thanks in advance!
