running rough won't idle
mort48883
i have a 35 horse honda its a 2001. i checked the spark plugs they look good but when its running i have nothing in one cylinder, i pulled one plug wire off number one cylinder and nothing changed in the running of the motor but when i pulled number 2 spark plug wire it runs on just one cylinder is there a MAJOR problem with one cylinder. but on the water it won't idle but if i put it up to 1000 rpm it will, and when i run it at 4000 rpm it runs good i need help ty
walt-oxie1
Re: running rough won't idle
The carb for that cylinder needs cleaned. Doing all the others will not hurt either. When you take the bowl off the carb, remove the big flat tip screw in the center of the carb body. GENTLY pry the tube out through the (front or rear) of the carb with a flat tip or small needle nose. Clean that tube with a small piece of wire or torch tip cleaner. There are 2 holes on the side of the tube and a restricter in one end of the tube, that is what usually clogs. Hope this helps.
psteurer
Dead-on advice. I have a 50 hp Honda. When I bought the motor, the dealer said the number one problem is clogged carburetors especially with today's fuel. The dealer said to always run the motor dry if you let is sit for 3 or more weeks at a time. There is also a screw on the bottom of each carburetor to drain the bowls if you prefer to do that as oppose to running it dry. The Owner's Manual recommends draining the bowls by the screw.
As a preventive measure, it is also recommend to run some type of fuel stabilizer. I run 1 oz of Sea Foam per gallon of gas. Sea Foam supposedly keeps the carburetor clean as well as removing carbon deposits. There are others like Stabil. But I have used Sea Foam on some older 2 stroke motors I have been extremely impressed by the results.
JUSTINTIME
carbs need a cleaning
but check for spark first on all cylinders
