Running temp for 3.0 tks mercruiser suntracker 27 ft pontoon?
Pdevito
the water here is 92 degrees. Crazy hot. The running temp on the boat at 3k rpm is 175 with a 160 degree thermostat. When i speed up it rises to 178 is that ok?
Scott06
Yep just fine exactly what my merc with a 160 stat runs at, even in cooler water.
I don’t think the alarm for overheat trips until 200 or 205.
Is this a new to you boat? If so, make sure to do all the maintenance the prior owner didn't do
Pdevito
No, it's not new.I just put on a brand new carburetor And temp sensor on it and didn't know if the mixture was off. still get a little after run every now and then
Scott06
I would fatten up the idle mix a tad, and make sure idle speed is down.
Was the old carb running rich ? if so maybe need to remove carbon from inside combustion chambers with sea foam or GM top engine cleaner
