running wiring for smartcraft
Dennisn
has anyone run wiring for smartcraft on a 2008, 1902
how big a project was it ?
cbrenthus
Re: running wiring for smartcraft
Yes, and it was a pain in the butt! I removed cupholders, deckhatches, etc... Kept getting close to the helm but running into bulkheads and couldn't get through. Took me several hours...
... until I found the conduit with the string coming out of it, then I had it pulled through in about 30 seconds :D Under the starboard side rear bin, there was a "string" screwed to the inside of the hull. That was the one that was pre-run through the conduit.
SoFloStone
If there is a pull string, make sure you pull a new one through when you pull the wire so you have something to pull the next wire through with...
Dennisn
thanks, that will make the task much simpler
those forums are great there is always someone who has been there done that
Killafornia
Same thing. I was supprised and happy to find that trophy had an extra 1 1/2" conduit plugged at both sides with pull line for running more electronics. But, I found it while doing something else so I did'nt have a problem when I was ready to add electronics.
Dennisn
i dont see the line on my 2008 1902. ther are three pipes running from the starboard well but no string
jm_bullard
Get a fish tape from your local hardware store and run it through. Then tie your rope to the end and pull it back out.
cbrenthus
Has anyone installed anything else? Did the dealer install a fishfinder?
