Runs but only if....
Tstates
I have an 1973 evinrude motor that I can get started, but can only keep it started if I keep pumbing the bulb on the fuel line. I rebuilt the carb thinking that would solve the problem, but it didn't. It has an old metal tank that doesn't have a vent, could it have something to do with the gas tank or maybe the fuel pump?
chbailey
Re: Runs but only if....
Is your bulb deflating before you pump or is it full?
kenmyfam
Take the gas cap off for a bit or loosen it so it acts like a vent and see what happens.
Tstates
The bulb seems to stay hard when I pump. If I give it a squeeze ever second or so seems to do the trick. I'll try opening the cap to see if that works.
Gary H NC
Could be a leak in the fuel system,fuel pump diaphram or maybe the ball.
See any leaks around the carbs lines when its pumped up tight?
Tstates
Checked the fuel pump diaphram and it looks good. Also don't see any leaks.
chbailey
After you pump it without the motor running does the ball stay hard or does it relax?
chbailey
Also, what kind of shape is that fuel line from the tank to the motor in?
Tstates
The bulb stays hard. I just bought a new fuel line because it was leaking. Any other suggestions?
F_R
Honorary Supreme Mariner
There are only two possibilities: Either there is a leak in the fuel line or the fuel pump is bad. The fuel line leak can also be where it plugs onto the gas tank, especially if it is an OMC tank with the two little push pins. There is a tiny o-ring around one of those pins and if it leaks the fuel pump will suck air.
