Motor runs all day at 3200-3400 RPM's, Will run about 5-10 Min at @4000 and temp will creep up then rev limiter kicks in...HOT. I wasn't paying attention and that was the only time It got that hot. Changed water pump/thermostats and same thing. The water pump that I replaced looks great, in tact, and still very plyable. Did not notice this when I bought it and tested it.
Pee stream is more of a thick spray than a good stream.
Water pressure stays below 10psi if Guage is accurate.
If there is a blockage (say part of an old impeller).. is there any advice on how to approach it?
Thanks in advance.
David
Thanks in advance.
David
