runs in barrel and crap on the lake? help
salmonite
so i have a 1990 6hp evinrude that runs like a dam dream in a barrel and then when i get it out on lake will only run at high rpms. it is the same combo of gas tank, hose and motor. I just dont understand? Kind of stumped... Thoughts?
Cofe
Re: runs in barrel and crap on the lake? help
When you are out to the lake, try backing the low speed needle out a little to enrich the idle mixture.
salmonite
yep did that
oldrudedude
How about advancing the timing at idle a little? Have you done a proper link/synch? Is the level of the fuel tank the same in the boat as in the barrel? Is this motor new to you? If not how did it run before?
1946Zephyr
It's electrical. Check the coils and wires thoroughly. It sounds like you have a coil arcing out on the mag plate.
salmonite
no not new to me... started doing it last year, ran pretty darn good before. I guess i probably have not done a "proper link/synch" as i would say i am at best a mediocre mechanic...
jtexas
can't remember...does this motor have a submerged exhaust? If I'm right and it doesn't, then could it be that the boat is floating lower in the water for some reason? Added a battery in the stern, bigger gas tank, gained some weight over the winter, different boat, yada yada yada
salmonite
It actually is a different boat but it started doing it on my old boat and then its doing it on the new one. Could it really be its sitting to low in water? Somebody else told me that
