Boomyal
- Joined
- Aug 16, 2003
- 12,072
Re: Rust/Iron in water...help!
Iron oxide fouling of a resin bed does not inhibit it from exchanging ions, ie, softening the water or removing dissolved iron ions. Iron fouling of softener mechanical components, that draw salt brine, may keep the resin bed from being regenerated. Just because you set the unit to use lots of salt and or go thru the regeneration cycle frequently, does not mean that it uses that salt.
Bought this place 16 yr ago, the softener check valve could not be seen as the chamber cover was coated with iron. The resin beads in the softener were also covered and the softener would NOT work, no matter how much salt you set it to use, or how often you recycled the system.
Local Water service Co told me to add 1 cup of Iron Out to the salt bin at every regeneration cycle until the check valve chamber cleared, then only add only once a month to keep it clear.
btw, dissolve iron does not foul resin or associated mechanicals. Only iron oxide does that. Dissolve iron does not convert to particulate iron inside the softener. The well has to be delivering a stream of oxide for fouling to take place. If you have sufficient iron oxide coming from the well, the softener will get plugged up and or fouled.
It worked. The Iron Out dissolved the iron coating the chamber and the resin pellets, as the water is very soft now.
I do have a cartridge filter in-line before the softener, but that only takes out the solids, keeps the faucet screens clear.
Iron Out powder, works great, but be very careful as the 'dust' created when pouring the powder can be EXTREMELY DAMAGING TO YOUR LUNGS.
